I recently just purchased a Rasa 750 kit and I noticed that some people say to test your loop for 8-12 hours before use.
1. Does the testing happen while its inside the computer?
2. Do you build it outside the computer and then test?
3. And if you do it outside the computer, do you put it in the computer assembled or do you disassemble it and then re-assemble in the case?
