1 - 16 of 16 Posts
Firts, sorry my bad english and second, sorry if i posted in the wrong forum.
OK i got an question, an PCI Express x16 2.0 card can run in PCI Express x16 expansion slot.
I'm NOT new to Overclock
What's the motherboard and whats the card?
If you're buying a new motherboard it will have PCI-E 2.0 slots. Any new card will work in it. it may just say PCI-E x16 because they will assume you know its 2.0 because its a new motherboard.
PCIe 2.0 x16 card will work in a PCIe 1.0 x16 slot because of backward compatibility. This is in general. There might be a few exceptions though.
(I do not remember the figure but the performance loss is something like a few %)
yes, it will
Originally Posted by Axmand
Nice, but if the motherboard have a PCI-E x16, an PCI-x16 2.0 videocard will work?
Not that I know of.
A PCI-Express card does not work in a PCI slot (both mechanically and electrically).
That's not what he's asking
He's asking if a PCI-E 2.0 GPU will work in a PCI-E 1.0 Slot.
Which it will
If thats what it says in the FAQ then yeah, it does.
The motherboard has to be SLi compatible, its like you can't put crossfire in a non-crossfire compatible motherboard.
Reactions: Axmand
Which it will
Yes, I replied with #5 that it will work.
However, OP asked a different question in #6.
And I replied to that post.
OK thanks everyone, another question, i already read the SLI FAQ thread it says in to use the SLI the motherboard MUST have nForce, its true?
If you use a modern motherboard with Intel X58 chipset, it does not need any nForce chipset on board.
No, not true, some of the low end mATX boards are still v1.1.
Yeah? you use them with HTPC's don't you?
Reactions: Axmand
1 - 16 of 16 Posts
