1 - 2 of 2 Posts
Retired
Hey folks, I have a question about the EULA of Windows in regards to how many times you can install it. I recently installed the RC1 vista on my computer. Can I use the same windows xp home install disk to install windows on another partition so i can dual boot? Is that ok?
The maximum amount of reinstalls on a key is ulimited.<br><br>
But you can only install using you key 3 times on different hardware or Computers.
1 - 2 of 2 Posts
