1 - 2 of 2 Posts
Is windows xp more stable for overclocking?
I want to overclock at least 503Mhz with the same stability level.
2.53 ----> 3.06
What Vcore voltage is preferred for this kind of overclock?
Right now , I'm usin 1.550 voltage.
1.7v is about max you should give it, as long as load temps go over 50C. As you're pushing, if you start exeriencing instability, kick vcore up one notch, boot into Windows, and check temps. All Intel overclocking answers can be found in the stickies (at the top of this section).
1 - 2 of 2 Posts
