1 - 2 of 2 Posts
Hey everyone,
I still have some systems with first generation i7 CPUs and there's something that bothers me for a long time. There's a theory all over the internet about "QPI must be higher than uncore", some people suggest 8:9 ratio for stability and to avoid 1:1 ratio.
Now technically, it does make some sense, so memory and L3 won't choke the entire QPI link. However, personally, I never experienced any issues or bottlenecks running QPI and uncore at the same clocks.
I'd like to get some output on this subject from others.
Thanks!
Iconoclast
No memory traffic passes through QPI on any single socket LGA-1366 part. There is no bottleneck implied by running uncore at or higher than the QPI link.
Many boards/CPUs are not stable beyond that 8:9 ratio, but some certainly are.
My best Bloomfield part on my X58A-UD5R 2.0 ran 24/7 stable at 4.2GHz core, 3.8GHz uncore, and 3.6GHz QPI. Same chip wouldn't even POST with uncore higher than QPI on my ASUS P6TD Deluxe, and I have other CPU samples that wouldn't work correctly with uncore higher than QPI even on the gigabyte board (though the Gigabyte board was almost always able to run closer ratios).
1 - 2 of 2 Posts
