Question on 24 pin connector.
396 Views 4 Replies 3 Participants Last post by  lilraver018
Is there such thing as a 24 pin right angle connector
something like this?
http://forums.bit-tech.net/albums/th...?dl=1228934178
I wanted to do some pretty amazing cable management on my new rig i ordered but i find that the 24 pin connector makes the case looks un-neat.
1 - 5 of 5 Posts
thats awesome because i have ben researching the same thing today.... i was also thinking about improving my cable management... i wish i could answer u but im gonna have to sub this incase u get some good responses
I have looked for the same item, but I had no luck either.
Perhaps you could buy This and shorten/mod it to your needs?
Thank you for the quick reply i appreciate it. I have to wait till my psu gets in. But i think i might just go with the route of bending the cables and then heat shrinking the cable into a 90 degree angle to have it hold its form.
i will pursue a solution.
1 - 5 of 5 Posts
