1 - 19 of 19 Posts
I have had this stuff laying around my desk area for about 1 year now.
1. Arctic Silver 5 compound
2. Arctic Clean Surface Purifier
3. Arctic Clean material remover.
Now is this stuff still good after being sitting around the room for going on a year? Temp been pretty good year round. All havent been left in any direct sunlight or nothing like that. Just wanna save some money
Was going to apply this stuff on my GTX 580 Block and CPU block
Pigeon Poop Enthusiast
I use MX-4. Great stuff with no curing time.
Reactions: Legiox
Originally Posted by Haze_hellivo
Artic Silver 5 is electrically conductive and may break your card.
If you're careless enough to spill it over where it's not supposed to be, maybe.
Get some MX-4 and use that.
I am getting really sick of this mis-information. If you don't know what you are talking about then don't open your mouth.
AS5 is not electrically conduction. It is slightly capacitive which is a big difference. AS5 is fine. It just has a cure time.
I switch over to MX4 because of better temps.
phenomenal swag
Turd ?!
He didn't call you a turd
. He said "well turd", like he was saying "oh, crap" or something.
This. AS5 is fine to use as long as you're careful with it. Just be warned that there is a period of time where it needs to cure after you've applied it, so you won't see an immediate improvement in temps.
phenomenal swag
Originally Posted by Legiox
Thanks for advice wholeeo. Now can i still the cleaner and purifier to get the TIM off the GTX 580 when it comes in?
+Rep to you sir
Yes. To be honest, you should see what your temps will be first before you apply the AS5. Maybe you won't even need to. I never like applying TIM to anything if I don't have to. I always manage to smear it and get an uneven application somehow (except for maybe one time, and that Venomous X is never coming off my 1090T
Discussion Starter · #15 ·
Thanks. I just ordered some MX-4 (not much in cost). As always this forums is ripe with information!!!! Thanks again to all.
If you are asking because you want to put a water "block" on, then AS5 is fine. If you are just getting a 580 and changing the TIM for better temps, don't. In most cases it won't do anything or even hurt performance if you do it wrong.
Agressive Perfector
AS5 is not outdated at all. I have put AS5 on my Radeon 9800 with good success (the old TIM dried up and my temps were sky high). The curing time was about 5 days and after that there were no issues. I don't know what it would act like on a newer GPU but it should work without issues.
Originally Posted by steven88
is arctic silver 5 still good for CPU? or is it outdated?
It is still fine. There are other TIM's out there that are "better" (by maybe 1-2°C), but if you already have it, use it. Do not make a special trip or order for another TIM.
Originally Posted by ComradeNF
AS5 is a bad idea on a GPU. MX-2/4 is pretty good.
I have used it on 10+ GPU's without any issues.
It is electrically capacitive, not conductive, big difference. It will not "break" a card.
Reactions: steven88
1 - 19 of 19 Posts
