1 - 3 of 3 Posts
hai guys i overcloking my graphics card and the temp is start from 47 C and its keep increase now is like 50 C should i get a fan ( i'm using 4141 rpm ) or its suppose to be like that
thanks
Are those temps with Stock clock speeds? If they are you should reseat it, and check how much thermal compound you got on there. Oh, lmao, I though that was the CPU till I checked the picture after I posted... lol
Nah, I think those are good temps for a graphics card eh.
thanks
No fan necessary, video cards get that hot all the time, in fact, thats a great temp for an OC'd card.
If you see the card hit 70...then you should look into more cooling.
1 - 3 of 3 Posts
