1 - 9 of 9 Posts
I usually see my card running warmer on the 511 WUs but usually I notice the harder WU's make any/all cards work harder so they get warmer.
Originally Posted by oulzac
I just noticed its not the just from folding, my card is running much hotter on everything, and the only thing that changed was the new 9.2 drivers. I think I may be buying some coolers for the card soon.
Have you tried cleaning the dust out of your cooler on your card?
Also, would you like some recommendations on coolers?
yeah, recommend away, I was just looking at the Zalam 900.
Dust? its less than a month old
Well, you are pretty limited on what you can do with your x2 card.
But I your best option is getting two of the Zalman VF900 (like you said).
Or you can mount a V2 & HR 03 GT but the dual VF900 setup is easier. And costs less.
It has roughly the same cooling performance as well.
Originally Posted by azcrazy View Post
well the 9.2 cat ,made my sytem so ustable , and with so many hard crashes that my HDD broke ,and yes it my 4870 was running way hotter than usual
Yea the 9.2s killed my OC stability. I kept getting driver resets and hard locks.
1 - 9 of 9 Posts
