Hello everyone, i have a question as follows........I have a 1800x at default settings ( i dont overclock) and was looking at the threadripper and the 2700x , i mostly play modern games like Wildlands i get
80fps on default high settings.
would the performance increase for me if i upgraded to a more expensive CPU like the 2700X, i did some reading that clock speeds makes the difference instead of more cores
is that true??
should i wait till the AM 4+ comes out or get a 1950X threadripper, but then most games dont use all cores. need some good advice??
thanks
Sovrinn
is that true??
thanks
Sovrinn
