1 - 5 of 5 Posts
So today i ordered.
i5 750
GTX 470
750W PSU
V8 HSF
1TB HD
Xcilo Blackhawk Case
Gigabyte P55 Mobo
G.SKILL 4GB RAM
I haven't built a computer since my Pentium 4.
So basically I'm asking does everything look like it will match up ok?
When i install the heat sink the V8 should be readable from the outside? I heard people saying the airflow was backwards.
And to overclock all i need to do is use the application that came with the gigabyte mobo?
Yup.
Itll work fine.
Overclocking shouldnt be too difficult, but you should definietly ask some questions in the Intel Motherboard or CPU section about it, once you have the computer working.
If you already have a DVD drive, OS, peripherals, and cables(some might come with mobo, but not sure), then you should be good.
Rosewill
looks like it will be a good little rig
Discussion Starter #5
Originally Posted by vonVanir View Post
Rosewill
Yea i was looking at corsair but i literally only had 1,050 and that would put me over :/ but the reviews on that psu look good.
Also i have keyboard,mouse,dvd,OS. I just hope it has all the wires.
1 - 5 of 5 Posts
