I'm going to completely refine my HAF932 in the next couple months. I've got a few questions about screws and rivets....
1.) What size screws do 5.25 (drive) bays use? Length in mm?
2.) What size screws do 3.5 (HDD) bays use? Length in mm?
3.) What size screws do motherboard standoff holes use?
4.) What size screws fit inside of motherboard standoffs? Length in mm?
I'm going to buy a Black Ice GTX360 radiator and Scythe GTs.
5.) What size screws do radiators use, and what length should the screw be? Fan is 25mm wide.
What are some good places to buy these screws from? I know for a fact that MDPC-X sells a ton of M3 screws...
6.) Rivets; dome-head or countersunk-head?
