If you have the Antec 1200 and/or the Asus Extreme Rampage II motherboard, or even if you don't, I have some questions.
1. If you have the Asus Extreme Rampage II, could you possibly look in your manual or off of your head tell me the maximum power ratings possible for the CPU fans without blowing the header? I would like to know if I need a fan controller for my upcoming build, because there will be two high speed fans cooling a 920 w/ a Prolimatech Megahalems.
2. I have some very high quality speakers and headphones, and I'm sure the quality of the supplied soundcard will be not be great, so what is the best all-purpose sound card I can get off of this page http://www.newegg.com/Product/Produc...20Express%20x1
3. If I get this soundcard, will I be able to use it in the bottommost PCI x 16 slot due to the lack of room in the top PCI x 1?
4. I would like to know what the best 120 x 38 CPU cooling fans are. When I get my Megahalems, I would like to setup a push/pull with two of these fans, and I am expecting some pretty extreme i7 OCing, over 4Ghz at the very least.
5. How is the Antec 1200's stock cooling?
6. What is the best 1000W power supply to go with the Antec 1200? Please help me choose one from this page http://www.newegg.com/Product/Produc...01%20-%201000W and keep in mind that the antec 1200 does not have a bottom fan grille so PSUs with bottom fans must be turned over, and this could mean that PSUs that are meant to draw in cool air are drawing in hot case air.
7. If my build requires a fan controller for whatever CPU cooling fans that are chosen, what is the best fan controller?
8. http://www.frozencpu.com/products/99...dow.html#blank This is the only place where I found custom Antec 1200 windows. Is there anywhere else that is cheaper?
9. Please tell me, straightforwardly, what you think the best TIM is and how I should apply it when I get the cooling components. Does it go on both the CPU and the Megahalems?
10. I have 3 OCZ Agility 120GB SSDs that will be used in a RAID0 Array in my upcoming build. I hear there is something called strip size. What will I set this as?
11. I hear there will be some extreme SSD deterioration because TRIM does not work while in a RAID array. Is there any way to get around this?
12. After I receive all of my parts and build my computer, what is every single piece of software that I will need? I mean software for stress tests, diagnostics, whatever software that is industry standard for system builders that overclock their systems and test for stability.
A million thanks to all who help me with my first build!
