So earlier today, I posted up here on OCN and determined I should OC my 5850 to 900/1200.
The card idles around 34-37°C (in 2D mode), and while running FurMark, hits 61°C (all according to GPU-Z)
My 1055T is clocked at 3.5GHz + 1.328 vcore. It idles around 27°C and while running Prime95's 'blend' tool, peaks at 46°C (according to Core Temp).
So, I was wondering, are my temps, idle and load, for both my 5850 and my 1055T normal?
Also, could I change anything in particular to make my 1055T OC 'better'..? I've been running P95 for 40 minutes and counting, if that is of any significance.
Thanks.
EDIT: According to CPU-Z, my NB freq. is 2.5GHz. Is this normal? I set it to Auto in the BIOS and upped the NB voltage one notch above what the BIOS refers to as 'Normal'. This is my first build/OC, so I'm not exactly established with how this scene rolls..
Thanks.
