If your TV passes deinterlacing tests it will set itself to 1080i.
If it doesn't, it will run at 720p.
Just set it to auto and let it do its thing. The difference will be so minor that it will be very tough to tell. 720p and 1080i are different types of interlacing and the difference between the two is very small.
I hope this helped.
I hope this helped.
