Quick Dual Boot Question
256 Views 4 Replies 3 Participants Last post by  volcomx2
I am going to try dual booting again with windows xp pro and vista x64 and I was wondering If I were to want to safely remove vista If I still have fps problems, is there a clean way without losing any of your files on the same hard drive? Thanks in advance.
1 - 5 of 5 Posts
no if you format the vista partition it will mess up the boot files an you wont be able to boot into xp. i did that once.
http://www.istartedsomething.com/200...-boot-with-xp/
that guide should help you unistall vista
So the options are using a different harddrive?
Thank you
1 - 5 of 5 Posts
