1 - 3 of 3 Posts
omg now i know...........
i opend my pc and i took out the ram i read the sticker that was on it, it says
pc3200 ocz el 2-3-2-5 . On the other hand, the ocz el in newegg.com says 2-2-2-5 i got bad ram or wat????????????
check your reciept and verify that is what you bought, maybe find a model number and check to see that it is listed as 2-2-2-5 and not 2-3-2-5, maybe you just thought u were buying and bought the wrong stuff... or maybe newegg gave you the wrong stuff...
but 2-3-2-5 is still good timings!! ill take it if you dont want it!!!
well they r sayin they can hit 240 on the other one :S.
1 - 3 of 3 Posts
