1 - 2 of 2 Posts
I am about to power my system on for the first time (my first full build), and I am trying to RAID also. Do I put the jumpers for master and slave respectively on the HD's?
Retired
If you are using IDE cables to connect them to the mobo yes, if you are using SATA then the jumpers do not matter.
1 - 2 of 2 Posts
