Introduction
Backlighting, LCD matrix type, resolution, size, efficiency, gamut, response times, input lag, contrast ratios, viewing angles, grey scaling, white saturation, black point, luminance, uniformity, bleeding. All aspects people take, less often then not, when purchasing an LCD. All present their problems discerning exaggerated facts with real world performance. Nothing more so then with contrast and backlighting. The static vs dynamic contrast story has been told countless times and is well documented, but just in case: Static dynamic contrast is what matters.
Backlighting however is an iffy subject mixed with manufacturer specifications, yet no documentation on test methodology, or results on hand or at the very least third party scientific measurements to provide a solid base for comparison.
Contenders
CCFL and LED. The 'old' vs the new. The mature vs the immature.
Just what exactly are the differences, what are the advantages of either? Why were LED's debuted as superior technology in both performance and green?
My search came up with a few conclusions and public mis conceptions but that's later to come.. But first let's begin with LED/CCFL manufacturer specification scandals.
According to manufacturers/public:
LED's are brighter then "typical" backlighting, being CCFL (public opinion I've gathered from forums/customers/public)
LED's offer 25% energy efficiency (manufacturer/public misconception)
LED's have superior life expectancy (manufacturer)
So let's touch each of these subjects in real world performance.
Brightness
Without a doubt LED's can provide more brightness if high quality LED's/enough LED units/ and enough power is supplied. Then again the same can be said about CCFL, increase CCFL numbers and quality and you can get a very bright panel. In both real world/manufacturer specifications they remain the same in LCD's, but why is it that the public sees LED's as being brighter? There's only one word to describe this: LCD monitor quality. Some perform to specifications (luminance specified) while most don't.
They likely saw a bad quality CCFL and saw a better quality LED and made the error to take that comparison to be the final verdict on LED/CCFL
Verdict: LED and CCFL offer same luminance in LCD's depending on quality of LCD as whole.
Power Consumption
This is without a doubt the iffiest subject in LED vs CCFL scenarios. Manufacturers claim 25% energy efficiency over typical* backlighting. The vastly common type of backlighting for LCD's is CCFL.
First the public misconception. I hear people all the time say LED's are more efficient then CCFL, and say it as a fact. Yet when I ask them for documentation for it, they fall way short.
I think the reason why manufacturer's 25% energy efficiency claim go unquestioned in the publics eye is because they fail to realize what backlighting is used in LCD's to begin with, even if they knew the name they would know little to nothing about the technology, cold cathode fluorescent lamp.
So when manufacturers come around claiming energy efficiency, people think "maybe they're talking incandescent light bulbs." Incandescent light bulbs, as you probably know, are the bulbs most used in your house. They are inefficient and run incredibly hot. There are alternatives to incandescents but they're costly, and they come in the name of CFL or compact fluorescent bulb. They are highly effiecient providing similar or better luminance then incandescent by far. 8w CFL is comparable to a 40w incandescent. 25-45w CFL is comparable to a 150w incandescent.
So of course when the public thinks of lighting they think incandescent, the most common form of lighting in houses. So when they hear LED's are superior in power efficiency in LCD's compared to "typical backlighting", they go without questioning it because it makes sense for them.
Next is manufacturer claims.
This is were it gets iffy. I could find no scientific paper comparing CCFL/LED's in LCD study by manufacturers nor third parties. I did however find an article by Alfred Poor regarding LED/CCFL usage in laptops.
Found here.
Overall when I researched I found:
CCFL's offer greater efficiency to CFL nearly 50% more efficacy.
LED's offer great efficiency too however no numbers have been produce in LCD usage.
In comparison there are experts giving the edge to LEDs, others to CCFL. There is no clear cut line. Apparently quality is what matters in the end.
In the end the biggest issue found is with CCFL's electrical requirements, needing high voltage (5v-48v) and low amperage which requires inverters/complex power supplies to allow for dimming. LED's on the other hand do not require inverters since they can [email protected] 12 or 24 Vdct and do not require complex power supplies.
Verdict: So in the end power consumption efficiency is unknown.
Lastly, Life expectancy
This is still an iffy subject but finally some light was shed when I did more research. I found something incredible. LED's offer the same life expectancy then CCFL's for the most part in LCDs. Keep in mind these life expectancies are for different applications not just LCD's, although I did manage to get some numbers)
CCFL life expectancy: 8,000-100,000 (25,000-75,000 appear to be common life expectancy in LCD's, I found no reference to 100,000 hour CCFL's used in LCD's)
LED Life expectancy (Dependant on color): 25,000-100,000 (50,000 hours is the common life expectancy in most applications** I found no reference to 100,000 hour LED's used in LCD's just claims that LED's "can" have life expectancy of 100,000 hours)
Keep in mind however LED's are subject to failing from heat, while CCFL do not.
**However life expectancy ranges from white, red, blue, etc. Red has the worst life expectancy, just how much worse I could not find however most sources say it's substantially worse.
Verdict: This is a very complex verdict. While I was able to pull up numbers I also found a lot of sources' resentment to LED manufacturers with their documentation/claims. Most criticized them for not:
* Specifying when the LED was considered dead (efficiency loss)- This is a major factor in expectancy. A few manufacturers answered claiming at 50% luminance loss was the LED considered "dead". The results showed 50,000 20,000 hours *I misread*. It would appear life expectancy varies greatly from manufacturer to manufacturer, its apparent to sources that luminance loss percentage was going to vary.
* Specifying LED's used (White, red, etc)
* At least publishing documentation etc. So far no publication
Sources:
http://www.eetindia.co.in/ART_880048...T_20be8751.HTM
http://www.instrumentsystems.com/fil...ystems_web.pdf
http://ca.news.finance.yahoo.com/s/2...s-proving.html
http://www.dominion.net.au/files/doc...20Brochure.pdf
*Others remain, however are pay for publications*
Contenders
Brightness
Power Consumption
Found here.
Sources:
