1 - 18 of 18 Posts
If not, please recommend a PSU. Thank you
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($549.95 @ SuperBiiz)
CPU Cooler: Swiftech H220-X 55.0 CFM Liquid CPU Cooler ($136.60 @ NCIX US)
Motherboard: Asus RAMPAGE V EXTREME EATX LGA2011-3 Motherboard ($458.57 @ NCIX US)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2666 Memory ($249.99 @ Newegg)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($195.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card (2-Way SLI) ($569.99 @ Newegg)
Case: Corsair 900D ATX Full Tower Case ($304.99 @ NCIX US)
Power Supply: Corsair 860W 80+ Platinum Certified Fully-Modular ATX Power Supply ($209.99 @ Amazon)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer ($49.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 Pro - 64-bit (OEM) (64-bit) ($129.95 @ B&H)
Monitor: Asus ROG SWIFT PG278Q 144Hz 27.0" Monitor ($765.99 @ SuperBiiz)
Total: $4957.97
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-01-04 03:49 EST-0500
I agree. That is DEFINITELY enough power. That's enough power for a pretty hefty overclock on all those components simultaneously, if you wanted to.
I run a QX9650 (130W processor) and a 980, and I barely pull 350 from the wall when I'm stressing everything.
Reactions: Feladis
Gaming Extraordinaire
Originally Posted by wooshna View Post
lol don't think he cares about price since the system itself is almost $5k. I'd personally wait to see if the ACER 1440p gysnce 1ms 144mhz monitor is true and any good before buying the ASUS rog swift.
Haha true
Senior OCN Member
Reactions: Feladis
Discussion Starter · #11 ·
I already own the Swifts but would have totally done that if I had the knowledge.
Originally Posted by shilka View Post
EVGA SuperNova G2 is better and cheaper then the Corsair AX and you dont need more then 750 watts for that system.
http://www.overclock.net/t/1482157/700-750-watts-comparison-thread-fully-modular#post_22109815
http://www.overclock.net/t/1496656/850-860-watts-comparison-thread-fully-modular#post_22435753
Thanks Shilka. I will make the change to the EVGA psu.
...when you walked in
Kinda wondering why you are picking the 5930K over the 5820K when you are only running 2 GPU's? There will be no difference in performance. The only reason to get a 5930K is if you plan on running 4 GPU's or 3 GPU's + other things such that run off of PCI-E(sound card, etc), otherwise the 5820K will perform identical because PCI-E 3.0 has plenty of bandwidth even at 8x.
If you push 980's hard with some types of loads and 1.25v, you might want to allocate 450w between them (but at low volts it'd be far less!). 250 for CPU at high overclock is a good idea.
Get a 5820k and plenty of case airflow!
Discussion Starter · #16 ·
Originally Posted by jaydude025 View Post
i suggested that too ya know
Thanks lol.
Good advice. I'll change that too.
Okay, I am actually building this for a friend who wants to spend $5k. If you had to put $300-400 more into this rig (assuming I changed to a 5820k and the cheaper PSU), where would you put it?
Doubled up RAM capacity, put money in the bank for when GPU's ~1.4-1.5x faster than 980 hit shelf middle of this year probably
It's kinda odd to have two ROG Swift's but not three, considering you can't really multi-monitor game with 2 monitors (best to use 1 monitor or 3+) and that's a huge price to pay for a secondary monitor
you could also just go all out and get 5960x instead of 5820k, for the two extra cores.
1 - 18 of 18 Posts
