Okay, here's my quick question:
When I went to go play CS:S, it said my video drivers were out-dated and needed to be updated, so I went onto the NVIDIA site, selected the options they wanted me to fill out and it found my driver. Now, I go under "Driver Installation Hints" (it says to read) and it says this:
* "Download Accelerator" utilities should be disabled when downloading any drivers.
* Do not run virus protection software in the background while installing the drivers. This prevents the driver from configuring itself properly.
* Before installing new drivers make sure you uninstall all NVIDIA display drivers from the Windows Control Panel. Browse to the Start Menu > Windows Control Panel > Add/Remove Programs and search for "NVIDIA Windows Display Drivers" or "NVIDIA Display Drivers" and select remove.
When I go to do the third step, I go into Control Panel and Add/Remove programs, etc. and all I see is "NVIDIA Drivers". It says nothing about "Display" in the name. Is this what I need to uninstall?
