1 - 3 of 3 Posts
Hello! Just aksing form this screenshot is it possible to identify how many pipes my card has....reason is that ati tool says 12 pipes but my score on 3dmark 05 is unusually low...(3500 3d marks) and on this there seem to be a lot of eights so i am thinking is this card actually 8 pipes only??? or 8 pipe bios? or something like that....may expalin my low score as seen in my previous threads thanks!!! Also says my card is 256mb but it is only 128 mb.....but my agp aperture size is 256mb...should i put this down? thanks
Your card is 12p as it's a GTO. The reason your scores are a little low is probably because you are comparing to systems with Athlon64 CPUs.
I'd take your Aperature Size down as well. 128Mb should be okay, but have a play and see what gives the best performance.
1 - 3 of 3 Posts
