Quick system building questions
299 Views 5 Replies 3 Participants Last post by  flushentitypacket
1. For the USB, I have two cables, each flat with 4 pins on the end. Do I just plug in one to the top row and one into the bottom row where it's marked USB?
2. Is HD Audio or AC97 better quality?
3. Can I plug in the front audio panel connectors into the sound card? I have an XtremeMusic.
If no,
Do I plug in the HD Audio to the AAFP or the SPDIF?
4. I have a 120mm fan on my PSU and it's inside a P180 Mini. The fan is therefore blowing directly upwards into the wall that separates the thermal zones of the PSU and everything else. Will this be...really bad?
1 - 6 of 6 Posts
I want to finish this today!!! Someone please help!!
1.yes
2.HD
3.no idea
4. PSU fans suck air in and blow it out the back
Use this pinout for your USB.http://pinouts.ru/Motherboard/usb_internal_pinout.shtml . Basically +5v is farthest away from the side with the key(missing pin). On the cable Red should be +5v
Originally Posted by pewpewlazer
1.yes
2.HD
3.no idea
Nice. Sounds like the PSU won't be an issue then.
Thanks +rep
1 - 6 of 6 Posts
