1 - 9 of 9 Posts
Looking for recommendations on a very quiet - quiet 80mm fan with blue LED lighting and a 3/4 molex connection. I need this for my CM 690 right side motherboard tray fan slot, and it NEEDS to be quiet because my PC is in my room and I have to be able to sleep with the thing on every now and then.
To give you a noise level estimation, I currently have 4xAntec 120mm Blue LED Fan's (Two at 80%), 1xScythe Kaze Maru 140mm (60%-70%), and the front panel 120mm on the CM 690 (60%-70%). I don't want to increase the dBA any more than that if possible.
I think you need a special thinner fan for that mount so it fits with the back panel, not any old 80MM will fit. I could be wrong but i think i remember reading about it in the CM690 thread.
Originally Posted by cs_maan
This is it.
http://www.newegg.com/Product/Produc...82E16835119041
With credit to Fletcher for finding it.
AHHHH i couldnt find it, thanks you. The search function on OCN reallllly sucks. It just brings up the CM690 thread that consists of 303 pages and over 3000 replies..... like anyone is going to want to dig through that for a simple question.
Haha yeah, I was just there like 2 minutes ago so I found it pretty quickly. There is a big selection at Performance PCs.
A regular 80mm actually fit? I might have to try this, I have an old 80mm tri cool.
1 - 9 of 9 Posts
