Quiet high cfm rad fans
1246 22
anyone know of any? right now i have some raging loud panaflos. im looking for something not loud at all to use with my 480 gtx.
Reactions: Teflon Tortise
1 - 20 of 23 Posts
· Premium Member
You either have loud and powerful or slow and quiet. You should just hook up your Panaflo's to a fan controller (if you haven't already).
· Premium Member
Cant you just put them on a fan controller?
· Premium Member
Do you have a fan controller? If you turn down the Panaflos, they will still move lots of air with plenty of static pressure, but with less noise
· Premium Member
Originally Posted by twitch101 View Post
yea they are on a rheobus. problem is...they dont undervolt incredibly well.....i just figured they may have been something quieter out there. guess im out of luck. thanks again guys
Well you can look at San Aces (which I use), they undervolt incredibly well and the 1011's outperform Panaflo's. Only thing is they cost more.
Newark.com sells Sanyo Denki fans (where I buy them now), so check them out.
· Banned
It says lead time http://www.newark.com/sanyo-denki/9g...fan/dp/96M1755 is 94 days with 0 availability. Add to the fact that they are 20 a pop. If he does a push pull, that's 160 for fans.
These are available though. http://www.newark.com/multicomp/mc19...fan/dp/70K8508
· Premium Member
Yup, that sounds about right. San Aces are very popular, so they are both hard to find and expensive. But, they are worth it if you're looking to undervolt a powerful fan.
Sorry, I bought their last 2 about a month ago. Just hooked them up to a fan controller an hour ago (they come "bare wire" so you have to do minor modding). They undervolt very very well indeed.
If money and weight are no object, newark does have some metal ones in stock. But money REALLY has to be no object at $91 each.
· Banned
So you need to sleeve and add a connector? Any pics of how they come?
· Premium Member
They just come with the tail.
· Premium Member
You can't have quiet fans that are high CFM. Your best bet is to buy high speed fans and use a fan controller to tame them down when you want more silence. Then you an turn them back up when you're gaming, when everything heats up.
~B~
· Premium Member
So how did you add a connector then? Twist+tape, solder, or twist connector?
Just put a 3-pin on it.
· Premium Member
~B~
Not sure if that is entirely true, yes they may still be noisy in comparison to a very quiet but thats all relative.
Things that change how loud a fan is gonna be for the same cfm are number of fins and fin design. Take for granted there are alot of roughly 70cfm fans that range from 28db to 40db, same cfm but huge changes in sound.
1 - 20 of 23 Posts
