1 - 4 of 4 Posts
Hi i have instabylity with my qx9650 when i oc it to 400fsb x 9 (3.2 GHz) so can anyone give me there bios settings/voltages
i realy want a fsb of 400 cause my gpu is slowed down
Tks
Eric
Mr.4way SLI
Try 1.35 or 1.375 on the CPU voltage and if you can 1.2 to 1.3v on the FSB. I dont know how different the bios is from my 780i but here is my settings on a Q9550 it should be close to the QX9650. Hope this helps some.
ok thx ill try that in 10 minutes but isint 1.3 hight for aircooling
i got gemin2 coller but stock its at 333x9 @ 1.18 load to 1.32 not load\\
just want a stable oc to get my gpu running without burning my cpu
last time i oc'ed i got it stable @ 400x8.5 with voltages set to 1.175 but monitored @ 1.18/1.2 load and 1.28 not load but when i boot up computer after while i shot down my cores wher eunstable core 1-2 @ 3.5GHz 3-4 @ 3.3GHz so that scared me off ill try again cause under normal specs i am stable maybe my mem voltage is to low 1.9 patriot pc3-12800 (rated 1.9) but can maybe push it @ 1.95/ 2.0 MaxMAX
1 - 4 of 4 Posts
