You disabled thermal throttle, a feature designed to protect the CPU from overheating.
What are temperatures at stock?
What cooler are you using? Is the cooler mounted correctly?
Motherboard? PSU? RAM? Linux distro, kernel version?
The freeze was likely an unstable overclock hard locking the system.
What settings were you using? Over 1.4V and that may have damaged the CPU anyway, although I'm perhaps overly cautious regarding voltages and others will be able to chime in with more knowledge.
If the CPU was actually running at 110 for a prolonged length of time, rather than the sensor reading incorrectly by +27*C (which is a known bug with Ryzen CPUs on Linux still) I'd be pretty worried.
