This is slightly hilarious, the fan is nearly bigger than the GPU! Glad to hear that this mod was a success!
Yeah I know it looks a bit silly, but I felt like doing this experiment. The bracket I ordered was made to connect 2 80mm or 90mm fans, but I figured using one 140mm would be more effective and less noisy.
Yes, you simply slide the fan into the bracket and the bracket will hold it below the card. The rubber grommets on the corners of the fan will also help to keep it in place in the bracket (no need for screws), it's quite firm.
1100 did not work out at stock voltage (which was pretty much to be expected) so for now I'm keeping it at 1050 with stock voltage and +15% power limit. This will run it at constant 1050 without throttling. I don't want to raise the voltage on this card but indeed I did try undervolting it. I believe -20mv worked at 1000 without any change to the power limit.Originally Posted by BergmanT
Awesome! I got two nb-eloop b12ps, considering to use 2 instead of one to make more airflow in the Ncase.
Nice youre going for 1100, that would be great. I have seen people giving the card less.juice and keeping it at 1050, with good temperstures, have you any experience with less volt on the card?
I'm using Gpu-Z to monitor temps and I don't have Afterburner or something like that installed to prevent issues with the driver. Which program do you use to read the VRM temps?
Ah I see, I already have Hwinfo but didn't know it could monitor the cards VRM temps so thanks for that. I don't know which brand card you have but my Sapphire came with too much paste on it. After replacing the paste with Gelid GC-Extreme I also saw a nice improvement (same temps but 10% drop in fan speed on auto mode).
Well those VRM temps were only from a 1 hour gaming session with a specific game. My son just used my PC for gaming for 3 straight hours and I let it record maximum temps and fan speed. Maximum VRM temp reached was 91c, maximum GPU temp 76c and maximum fan speed was 1200rpm (it can go up to 2000). This was at 1050/500 with stock voltage, automatic fan speed and +15% power limit.
Did you leave the settings at 'auto'? What temps did it reach? A 140mm would surely cool better because it covers more area of the card. Or 2 x 92mm perhaps (BeQuiet Silentwings fans?).Originally Posted by BergmanT
Just changed the paste last night, and added the 120mm fan, without the bracket but with cabelwire(or what its called in English :-D) The Noiseblocker cant keep it cold enough even with 1300 rpm. Maybe i must invest in a 2000 rpm fan from NB or should i invest in a 140mm fan? both will fit my Ncase..
But the silence in idle is just beautiful![]()
I manually adjusted the curve so it will hit 100% at 76 degrees. It wil go up to 84.. Just think i will invest in a fan with more power, just thougt that it wil be enough, also when i changed the paste, there was way too much used
