1 - 12 of 12 Posts
Swiftech MCR320-QP Triple 120mm Radiator
or
TFC Xchanger - Double Radiator 240
And is the Swiftech MCRES-Micro v1
or
Alphacool Cape Coolplex Pro 50 Reservoir
· Premium Member
Hi.
For reservoirs, of the 2 you posted I would go with the Swiftech as it is a fraction of the cost, it is smaller and the mounting is quite versatile.
If you like the tube-type reservoirs, then perhaps the EK-150?
For the Radiator, I would be inclined to go with the Feser model, but I do not have numbers on thermal dissipation to make a qualified call.
Originally Posted by Syrillian
Hi.
Does the swiftech res come with mounting hardware?
· Premium Member
If you buy new, then yes. It comes with a bracket and all the mounting hardware.
If you buy used, you will need to ask the seller specifically what is included in the sale.
I am buying it new and what will be the best tube size? Does the pump and rad come with fittings and if not what fitting size should i take?
· Premium Member
Get 1/2" fittings and 7/16" ID tubing.
I am purchasing all my w c parts from www.overclockers.co.uk but all the good pumps such as the mcp 655 pump are out of stock and that is the only one to my knowlegde that I know is good. Can someone show me the best one the offer in stock there?
· Premium Member
The only pump they have in stock is the XSPC 200 Bay Reservoir & Pump.
I would look somewhere else or wait.
Edit: Yes, FrozenCPU is a reliable vendor.
It seems like all the pumps are out of stock
so my question is. Is the website www.frozencpu.com A reliable good website?
I just checked Frozen cpu and they have the pumps in stock and they are a reputable company I have done business with them before and have no complaints
Originally Posted by slickwilly View Post
I have done business with them (FrozenCPU) before and have no complaints
Yeah, I've also done business with FrozenCPU before, and I've never had any problems. I stick pretty much with a few online venders when ordering computer components. NewEgg for general stuff and Petras Tech Shop for anything remotely pertaining to computer water cooling.
This is only my opinion and I realise there may be other excellent online vendors. I've only ordered from US dealers (because I live in the US) which may be a limitation
I wish I could help you on the rad question, but I'm sure there is some WC'ing guru that can
DCing for the CURE
1 - 12 of 12 Posts
