Just wanted a few questions answered before dropping $1800 on a gaming laptop.
Are you satisfied with driver stability for the 7970m?
How close is it in performance to the gtx 680m or gtx 675mx?
Considering that the ps4 will be using a 7970m do you think improvements for the laptop version of the gpu will keep improving?
Looking at getting the sager np-9170 with either the gtx 675mx, gtx680m or save some money and get the radeon 7970m if stability is there.
Also if i understand correctly enduro cant be turned off on clevo/sager laptops, whats a good alternative to clevo/sager that would have the amd gpu but have the ability to turn enduro off?
Thanks for your answers.
