Radeon 9800 PRO OC'ing to only 396/356? Why can't I go higher?
1446 14
I have a Sapphire 9800 PRO 128 MB 256-bit w/ R360 core and Hynix memory. I've added a VGA Silencer GPU HSF and Copper Ramsinks.
I'm using ATI Tool v.0.0.22 and ran Max Core and Max Memory for an hour separately and can only get to 396 Core and 356 Memory.
What am I doing wrong? I've read about folks OC'ing higher than that with STOCK cooling... I've got upgraded cooling and STILL can only get to 396/356...
Any help/advice is greatly appreciated!!!
1 - 15 of 15 Posts
Thanks! Been lurking here for a while, but decided to throw in the towel and get some help from all you great folks!
The default speeds are 378 Core and 338 Mem. I'm hoping/expecting to get to XT speeds of 412/365... but am now concerned...
Discussion Starter · #6 ·
Got AS5 on the GPU before I put the VGA silencer on... and the OCZ BGA Ramsinks had thermal tape that is pretty good so I didn't need any AS5 on those...
BTW... I'm running Catalyst 4.1 drivers... could I possibly see any difference trying different drivers? If so, which ones?
you DO know that stock ATi drivers have WEIRD anti-overclocking stuff built in to them....right? anyways id suggest using the omega drivers http://www.omegadrivers.net/ they have radlinker and MANY other utilities built in, including the newest ATi feature "AI" which is supposed to own...i can get 1300+ fps in counterstrike with everything set really low lol
Discussion Starter · #11 ·
Actually, no I did not know that the ATI drivers had anti-overclocking stuff in them... I thought the ATI tool would get through that... are there any risks associated with the Omega drivers?
Could my case just be overall too hot and that would cause me to not OC very high? Or could another system component cause this as well?
1 - 15 of 15 Posts
