Okay, I will not be using a shroud so I already know that I will have my fans in push, but my question is should I have...
-The fans pulling air from outside the case, pushing through the radiator, and exhausting heated air into the case?
or
-The fans pulling pre-heated air from inside the case, pushing through the radiator, and exhausting the rad-heated air out of the case
For reference I am using a haf 932 with a triple rad on the top, I am keeping both of the other stock intake 240 mm fans, as well as the 140 mm rear exhaust, water cooled components are going to be both GPUs and CPU (sig rig)
Sorry for the long post...
