1 - 4 of 4 Posts
who knows
I have an alphacool 480 rad, one of the sides is starting to come off. Can anyone give me ideas or help fixing the radiator would be appreciated. If this is in the wrong section please let me know.
Shooting down fallacies
If you are running it in push/pull, the fans being mounted will hold it together. Same goes if you are using that side as a mounting point.
I would epoxy it as already suggested, but it's not going to fall apart if you don't once it's mounted.
1 - 4 of 4 Posts
