Cooling an i7 and 2x 5870 reference on single loop.
For top rad my question is would a thicker rad be a better choice than slim with push/pull?
360 slim 25mm with 6 GT AP-15 in Push/Pull
360 non slim up to 50mm with only 3 GT AP-15's on it
Any recommendations on this rad?
In the bottom of the case i can do one of these:
140mm with a push/pull setup coming in from front of the case directly
or
240mm thick rad with push/pull setup - however the channel it will be sucking air from or exhausting is small, i can post a picture if that helps explain.
On both questions i could use a recommendation on the radiators to use, if i go with the slim on the 360 i have been thinking:
http://www.performance-pcs.com/catal...oducts_id=4541
or
http://www.performance-pcs.com/catal...oducts_id=4185
Thanks so much for the help
or
or
