Originally Posted by Juggalo23451 ![]() 240 Feser rad http://www.ncixus.com/products/28900...3/Feser%20One/ 480 rad http://www.ncixus.com/products/33299...3/Feser%20One/ |
Originally Posted by ChielScape ![]() like i said, that PA will never fit, its got a different spacing for the fans. |
Originally Posted by ChielScape ![]() i dont know.. people here have weird preferences sometimes... even though the GTX and Feser are completely superior to the PA, the PA still sells great. It's all about the what people use and therefore recommend... the Magicools just havent made a name for themselves yet... i bet if more people here buy them they will fly off the shelves. but this is the rad i meant though... http://www.performance-pcs.com/catal...ducts_id=23793 as you see its copper plated instead of painted... this greatly improves heattransfer. the plating is also present on the inside, so it will conduct heat from the water to the tubes better... if they ever release a 480 dual row version i'll be ALL OVER it. as the description says, the end tanks are made of polycarbonate (lexan) rather than acrylic, so they wont crack. |
