1 - 15 of 15 Posts
Hardware Maniac
Hello
Cant find info on google so im back here
Do the z97 chipset will handle 3-4x 250 samsung ssd in raid 0 ? And give decent output?
Just looking to have instant game loading hehe
Installed bf2 an old game and realised that my 512gb load the map in like 5 second. it took me like 3 minute + back in the days
Would be nice to reduce loading in bf3 bf4 gta v and arma 3 etc
Originally Posted by bonami2 View Post
Hello
Why daisy chain several SSDs, when just one really fast SSD will do the job..
http://www.newegg.com/Product/Product.aspx?Item=9SIA12K3G96790
Hardware Maniac
it should. My x79 could do 3-4x raid 0. I think on linus videos you start to lose speed after the 3rd one already. So 2x in raid is good, 3x if you're rich. If you can afford 3x raid 0 samsung 850 evo. You could also look into a ups for your computer and do 64gb ram and use 32-48gb as ram cache using softwares like primocache. Sure m.2 is fast or 2 in raid 0 is fast if you have two of them but yea the ram cache will eat them for breakfast.
Here's a fellow z97 using it.
I've been checking out the MSI Z97 Gaming 7 MB
When the M.2 slot is used, SATA 5 & 6 will not work, but it does not say anything about the PCI-E Express 3.0 slots being effected when the M.2 slot is being used.
You might want to email MSI's tech support and ask them if the PCI-E 3.0 slot are effected when the M.2 is being used.
Using just one M.2 card will be so much easier (and cheaper) then try to RAID 3 or 4 SSD drives.
As m.2 port takes 4 lanes it usually disables the last slot. As you can see in details at the pcie 3.0 possible combinations it shows as 16 0 0 / 8 8 0 / 8 4 4. Using the m.2 would be the last option 8 4 4 with the last 4 lanes given to the m.2 slot. So what is left would be 8 and 4 lanes making crossfire possible but not SLI.
to answer your question without trying to push you in some other direction that you arent asking about. it looks like your z97 would support a 6 drive array without any further modification due to the fact that 6 ports come direct from the chipset and only the remaining 2 come from the ASmedia controller.
On-Board SATA
• Intel Z97 Express Chipset
- 6x SATA 6Gb/s ports (SATA1~6)
- 1x M.2 port*
- M.2 port supports M.2 SATA 6Gb/s module
- M.2 port supports M.2 PCIe module up to 10Gb/s speed**
- M.2 port supports 4.2cm/ 6cm/ 8cm length module
- Supports RAID 0, RAID1, RAID 5 and RAID 10***
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology and Intel® Smart Connect Technology****
I could see this handling fine
Depends on the board if the M.2 takes any lanes at all.
Be careful about blanket statements like this as all motherboards are not equal.
I have an Asus Z97Pro-WiFi (a/c) that offers 2x PCIe Slots if I use a PCIe based M.2, otherwise it's SATA.
1 - 15 of 15 Posts
