1 - 4 of 4 Posts
Mobo is an asus rampage iv black edition.
I have a win10 ssd in sata port 6gbs and two hhd's (no OS) in raid 0 in ports 3gbs.
I setup the raid correclty and everything was fine. Now I can only boot from the ssd if I change sata mode to AHCI. Nothing I do with the boot manager will work when I have it on raid mode.
If I force boot the ssd I just get this.
Did you install Windows while your system was set to RAID mode?
If not, that may be why.
You may be able to restore boot functionality under RAID mode by running the Repair tool found on the Windows installation disc.
1 - 4 of 4 Posts
