O.k., once I make it to the "Array List" in the Media Shield Utility, I do NOT have the "Set Boot" or "New Array" options available to choose.
2 WD 250 Caviars for RAID 0
NVIDIA Raid Fuction "Enabled" in IDE Configuration window in BIOS
Drives are on SATA1 and SATA2 ports
SATA3 and SATA4 are Disabled
In Raid Utility:
Set mode to striping
striping block @ 128KB
moved both disks from Free Disks window to Array Disks window.
When finished (F7) option to clear disk data. I select YES.
Then I am taken to the ARRAY LIST and I see:
BOOT Id Status Vendor Array Model Name
N/A 2 Healthy NVIDIA Striping
I am curious as to why BOOT shows N/A? I cannot select the option to Set Boot or [N] New Array. I can only select [Ctrl-X] Exit and [ENTER] Detail.
Any ideas?
In Raid Utility:
Any ideas?
