Raid 5
368 Views 4 Replies 4 Participants Last post by  spccraig9
I have 4 WD 750GB in a RAID 5 array. I have the 5th 750GB as a stand alone for the OS and program files. I am running Windows 7 and I want to get rid of it and go back to Ultimate 64bit. If I format the stand alone drive and then install ultimate 64bit, will I have to rebuild the array?
Thanks
1 - 5 of 5 Posts
The stand alone should not affect the array. The computer should see those as 2 distinct partitions.
Just install the OS and format the drive when it asks you to. You should be fine with your array.
Yep, just don't format the array and you'll be good to go.
Sweet, thank you all. I kinda thought that was the case, but I wanted some assurance.
1 - 5 of 5 Posts
