RAID drive showing as non-RAID?
416 Views 2 Replies 2 Participants Last post by  dralb
OK, I just did a tear down of my main for some cooling swaps and some cleaning. When I rebooted (after clearing CMOS etc.) one of my RAID drives was showing up as a non-RAID drive. No matter what I did, I could only get one of the drives to show as a RAID partition.
I ended up wiping it and creating a new partition, but just curious as to why that happened.
1 - 3 of 3 Posts
Probably when you cleaned the CMOS. I assume you mean removing the battery.
Now, it SHOULD have rebuilt the RAID array after a CMOS wipe, but who knows why it didnt. At least you got everything working again
I cleared with the jumper. When clearing CMOS and using an onboard controller, you still need to go into BIOS and set it to RAID. the weird thing is I have done this plenty of times before and it has been fine. This time, one of the drives kept showing up as a non-RAID drive while the other did.
I switched SATA ports and it was always the same one. No matter what I tried, I couldn't get that one drive to show as part of the array. I did fix it, but that was by wiping it all and creating a new array, lol. No big deal as I was due for a fresh install anyways, but I would like to know so I can fix it if possible when it happens again.
1 - 3 of 3 Posts
