1 - 16 of 16 Posts
I configured RAID in my bios settings and made my two hard drives Striped. I got 2 WD Caviar 500 gig hard drives. When I went to setup xp it didnt recognize the drive. I have the ASUS M4N82 motherboard. Do I need some kind of driver for xp? If so, can someone send me a link I can download?
Thanks
Windows XP does need the RAID driver in a floppy drive (1.44MB).
You can download it from the ASUS support website
http://support.asus.com/download/dow...Language=en-us
The name of the driver seems to be:
"NVIDIA AHCI/SATA Driver for Windows XP/XP MCE/XP 64bit/Vista 32bit/Vista 64bit."
But this is my problem. MY ASUS M4N82 doenst support floppy drives!!! What do I do? can you use flash drives? (to be honest I was just told that floppy drives werent supported but non the less I only have one IDE port in my mobo and my dvd drive is IDE so im out of luck) If i got vista would it have the driver thing I need built in the disc so I could avoid the floppy drive method?
As I understand, that is a real problem with XP and RAID arrays, I understand you can't avoid using the Floopy.
Maybe somebody else in OCN has a turnaround to this problem on your MoBo
With regards to VIsta, you're right!. You can put your driver from anywhere (flash, cd, etc)
Now here comes my next problem. Me being the dumb one I can't find the "NVIDIA AHCI/SATA Driver for Windows XP/XP MCE/XP 64bit/Vista 32bit/Vista 64bit." driver you are talking about. I searched for it on google and got some AsRock thing. Is it on the ASUS site?
Sorry :[
FOUND IT!!!! Thank you sooo much. Now all I have to do is get Vista.... ha but thank you so much for your help. And with the file do i put the whole thing in the usb drive or only certain parts of the file i downloaded.
I don't know for your particular MoBo, but usually there's a tool in the downloaded file to create the "raid driver disk"
Discussion Starter · #14 ·
vista wont recognize the hard drive either. I've put in my flash with the vista 64 driver in it but it doesnt really do anything
am I supposed to take a certain file out of the vista 64?
1 - 16 of 16 Posts
