1 - 8 of 8 Posts
I TeK things...
i dunno not my cup of tea......
well raidmax psus aren't really that great... what is your budget?
you will typically want to stick w/ good brands: OCZ, seasonic, antec, fsp, enermax, sunbeam.
for a budget the sunbeam nuuo is probably the best-83 at zipzomfly.
for a bit cheaper go w/ fsp. if you don't have a large budget at all... then Aspire would be better than raidmax
http://www.newegg.com/Product/Produc...82E16817148027
I TeK things...
Discussion Starter #5
max 50ish kinda short on cash since i just got my GTO2
yeah, the sunbeam nuuo is highly reccomended and you can get it for cheaper from zipzoomfly.com
http://www.zipzoomfly.com/jsp/Produc...uctCode=370212
you you don't have that much then I would suggest you get an FSP psu... you can get a decent one for 50-70 range from newegg
if not, then go w/ an aspire. there is one for as cheap as 30 after rebate from newegg
Fortron got good reviews at Tom's hardware. I can't believe I've actually seen a thread that recommends ultra and raidmax. Yikes. You might want to do some google review searches before buying . Your other components are decent and its a shame to buy a poor quality power supply, especially if you intend to OC your system. Buy a Seasonic, OCZ, Antec or maybe the nuuo sunbeam that Solz is supporting so strongly (looked at a couple of reviews and it seems pretty solid).
1 - 8 of 8 Posts
