1 - 13 of 13 Posts
what are the stock timings? is it 1600MHz ram or did you overclock it to 1600?
well I got some vengeance here with 9 9 9 24 1t @1600MHz
Originally Posted by lilraver018
Its fine, might need to bump up the voltages if you try to tighen up the timing more.
I would jut keep them at 1333
you wont notice the difference much in day to day activity unless your uncompress zip files like a mad man.
i think that i gonna stick with your advise
thanks
CL11 on 1600? strange...
phenomenal swag
LOL, that's some garbage RAM if so. I can't imagine any RAM marketed toward overclockers or gamers (that's what the Sector 5 branding is for, right?) to be that bad. You probably just need to pump some more volts through your sticks.
That's some bad timings. I'm running 1866 vengeance at 1774 7-9-8-15 2T and people call that bad. Try running > 1.6 volts to the dram and do 9-9-9-24 timings.
Sent from Windows Phone 7.5 using Board Express
1 - 13 of 13 Posts
