RAM and CPU fps effect
871 Views 8 Replies 7 Participants Last post by  Powermonkey500
I've been looking for this online, hard to find... what sort of effect would upgrading my ddr2-800 RAM to a higher frequency have on my FPS? Can anyone point me to some video game benchmarks of different frequency RAM?
Also if i upgraded from my e6750 (65nm) to a 45nm quad core what effect would that have on FPS in games?
1 - 9 of 9 Posts
In some games the dual to quad would get you more then increased speeds of RAM. Depends if its threaded for that and going up in speed might get you some performance like maybe 1-2fps.
most newer games can utilize 4 core optimization, but not all games can, if you want to spend the money on it it will be well worth it not only for now but for future proofing as well. Also the ram will get you better performance being the faster the ram the faster it can utilize the data coming to it, and transfer it.
the only real jump in performance you will see is if you go from ddr2 to ddr3 as far as ram goes so your best bet would be cpu
ok.
is that the general opinion?
Going from DDR2 667 to DDR2 800 you won't see a FPS gain, been there done that
going from a dual to a quad you will see a difference in some games, probably the newer ones because there optimized for four cores ^_^
if you can wait until tomorrow or tonight i will run a benchmark of something just recoomend me something. Maybe i can do crysis, but what settings would i need to set it to so my GPU doesnt bottle neck it?
I will do a bench of two extremes. I'll do 2.53Ghz w/ 667Mhz ram VS 4Ghz w/ 1130Mhz ram
I highly doubt there will be any seriously noticeable effect. I've already tried crysis at 1440x900 with my CPU at 2Ghz then compared it to 4Ghz, i think there was a 0-2fps gain!
Power I will start with some generalities. RAM unless you can keep the same timings you will not gain going to 1066Mhz. If you can keep the same timings you will get little to no benefit as 80Mhz is not the bottleneck.
OK on to CPU? Well mostly at super high resolutions Quad does help on some not on others. I mean above 1900x1200. And further we are talking best case 5-7 FPS at best. Not exactly great improvement? And that is not on your system as I am talking higher resolution than you have.
Your GPU does seem to be the very best component. I suspect CPU could be the next upgrade. But short of benchmarks doubt you could tell.
I could look for the high resolution Duo vs Quad benchmarks but not easy to find. I hope you just trust me?
If I have not said clearly enough? DDR2 to DDR3 with looser timings gains you nothing.
Your system looks fine to me. That said your next upgrade is CPU. Then RAM then HDD.
But please buy a Sound card before anything else.
Your system is balanced nothing needs to be done.
3 FPS does nothing when avg is 60, heck even 35 means little.
Reactions: 2
Thanks a lot!!
definitely going to upgrade cpu before ram.
but as you said, i will get a sound card first =)
1 - 9 of 9 Posts
