RAM Architecture Compatibility Question
487 Views 4 Replies 4 Participants Last post by  incurablegeek
I would assume the answer to be yes, but I'm taking no chances.
Can I swap: Kingston Technology HyperX Blu 2 GB 1600 (PC3 12800) 240-Pin DDR3 SDRAM KHX1600C9AD3B1/2G
Amazon.com: Kingston Technology HyperX Blu 2 GB 1600 (PC3 12800) 240-Pin DDR3 SDRAM KHX1600C9AD3B1/2G: Electronics Amazon.com: Kingston Technology HyperX Blu 2 GB 1600 (PC3 12800) 240-Pin DDR3 SDRAM KHX1600C9AD3B1/2G: Electronics
404 Looking for Something? 404 Looking for Something?
for one of the RipJaws?
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Produc...82E16820231277
If the Kingston (1 pc.) is compatible, then I can slide it under the Tuniq Tower and still use the other 3 2 gb ea. Ripjaws.
This problem has arisen from the low hanging Tuniq Tower Extreme and the "reaching for the sky" RipJaws not playing nicely together.
Note: I'm not sure if the RAM architectures being different between the Kingston and the RipJaws will make a difference.
If you feel this to be a blithering idiotic question, don't hesitate to tell me. I read a lot and that raises many odd questions.
1 - 5 of 5 Posts
totally fine to mix and match ram.
although you will have to set the voltage to 1.65v instead of the previous 1.5v.
I don't think it would be the best idea. You usually want to keep the same models. There could be a decrease in performance.
The different rated voltage may cause problems with mix/match - do so with caution.
You're 100% correct, oh Precocious One. I see now the voltages are different, so not mixing them is just common sense. My Oops!
Anyway for me the issue is now closed. Btw, I went to your website and watched the music video you shot. Impressive. Will PM you later.
1 - 5 of 5 Posts
