1 - 9 of 9 Posts
I need to the best RAM Booster program for my old pc (PIII 600,128MB RAM
It's very slow !
512 would be a a good target.
A good video card would help. That even have AGP?
What OS you trying to run?
It should have AGP; most Pentium systems or later have an AGP slot. My 200MHz pentium that i bought off my neighbor for $5 has one.
Discussion Starter #6
VIA Apollo 133, PIII 600 MHz slot 1 (512KB) + TNT2 32MB AGP 4x @ AGP 2x
OS: WinXP SP2 (lol)
2 Questions:
1. VIA Apollo 133 can support "SOFTWARE AGP 4X (VIA 133/4x)
" with a program and I install it, but it runs at 2X ???
2. Is PIII 600 MHz, FSB 100, slot 1 (512KB) better than PIII 800 MHz, FSB 133 (256KB) ?
I think your find that the P3 600mhz L2 cache runs at half the clock speed eg. 300mhz
The P3 800mhz L2 cache runs at full speed (800mhz) better i think.
I have a similar setup. A P3 650MHz, Asus P2B-VT (Kestral), which orginally had 128MB RAM that I upped to 640MB. The improvement in operation was phenominal. Even with XP SP2. I also put in an old Vid Card that I had, nVIDIA Geforce MX 200, used Coolbits to overclock it. So it has somewhat decent graphics, for being an old computer used as a backup anyway.
My suggestion is to get ahold of some old computers and harvest their RAM. I am sure yours uses SD. Also, Check for a BIOS update. Use the RAM optimizer that other helpful OCer suggested. Lastly, disable everything. Go through this XP Optimizer guide and do everything you can to decrease Windows running requirements.
http://www.overclock.net/faqs/36430-...uide-tips.html
http://www.overclock.net/faqs/40428-...uide-tips.html
Hope that helps! Good Luck!
1 - 9 of 9 Posts
