1 - 5 of 5 Posts
What does everybody think of this ram? <a href="http://www.memoryexpress.com/index.php?PageTag=&page=file&memx_menu=EmbedProductDetail.php&DisplayProductID=8745&SID=" target="_blank">LINK</a><br>
and seeing as i live in canada, i tend to only shop at memory express
As much as I luv Corsair, that's not the kit to go for that price. Just to give you an example of what Corsair you should be looking at for that price: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145043" target="_blank">Dominator</a>. <br />
<br />
Otherwise the <a href="http://www.memoryexpress.com/index.php?PageTag=&page=file&memx_menu=EmbedProductDetail.php&DisplayProductID=8736&SID=" target="_blank">OCZ 2GB PC2-6400 EL Platinum XTC Edition Rev. 2</a> will make a fine choice and maybe better than the PC2-8500 from Corsair AND less expensive. <br />
Also good latencies for the Voltage.
If you must go with corsair then I would look at one of the following:<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145034" target="_blank">http://www.newegg.com/Product/Produc...82E16820145034</a> (Very good up to DDR 900+)<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145043" target="_blank">http://www.newegg.com/Product/Produc...82E16820145043</a> (Better heat spreaders)<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820145044" target="_blank">http://www.newegg.com/Product/Produc...82E16820145044</a> (This is what I currently run)<br><br>
PS - The price is awfully high that you showed
NCIX seems to be the cheapest for ram in Canada right now (New Egg does NOT ship to Canada) , you don't need 1066mhz ram cause your are probably not going to get a 533mhz fsb on the e6400. PC6400 is going for an ok price here is the link<br><br><a href="http://www.ncix.com/products/index.php?minorcatid=105&subminorcatid=80" target="_blank">http://www.ncix.com/products/index.p...bminorcatid=80</a>
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>mtuccio</strong>
</div>
<div style="font-style:italic"><br />
PS - The price is awfully high that you showed</div>
</td>
</tr>
</table>
</div>yeah but you have to remember that is in canadian dollars and for some reason lately our ram prices are very volitile they change everyday
1 - 5 of 5 Posts
