1 - 4 of 4 Posts
I think it makes your RAM run at a lower frequency. When you overclock you'll make up for that.<br><br>
Edit: Also helps achieve a higher overclock.
it makes you able to raise the FSB past the speed that the ram can handle
Overclock Failed...
<div>Originally Posted by <strong>Gregor222</strong></div>
<div style="font-style:italic;">an someone clarify the whole ram divider thing for me? help would be greatly appreciated</div>
</td>
</tr></table></div>
Sorry to jump in late:<br><br>
FSB x Multi = CPU speed<br>
FSB x Divider = Memory speed<br><br>
As you raise FSB, eventually either the CPU or the memory will fail.<br><br>
So you can use a divider to control the Memory speed separately from the CPU speed. And use a Multi to control the CPU speed separately from the Memory speed too.<br><br>
You could download one of these memory calculating programs and play with it. They will explain alot for you.<br><br>
A64 Calculator: <a href="http://www.geocities.com/edgemeal_software/" target="_blank">http://www.geocities.com/edgemeal_software/</a><br>
Blue's AMD Athlon 64 Overclocking Calculator: <a href="http://www.gurushane.com/site/software.aspx" target="_blank">http://www.gurushane.com/site/software.aspx</a>
1 - 4 of 4 Posts
