1 - 4 of 4 Posts
So in my bordom I decide to start playing with my RAM (that sound bad I know), and seen a few thing I have to ask about.<br />
1. What does performance mode do, I mean like technically what takes place to increase performance.<br />
2. Also should I enable it or disable it...at the moment I have it enabled, but I just enabled it.<br />
3. By disabling it can I tighten my tomings at all, I tried for 2-3-3-5 but I couldn't boot. I was previously at 2.5-4-3-5 and tightend them to 2.5-3-3-5. I know that it's not much but every littlement bit ya know.<br />
I have more but I have to go back and check so I will need to EDIT... BRB.<br />
<br />
EDIT:<br />
Ok here is the rest<br />
4. What is this and what does it do?<br />
DRAM Idle timer,<br />
I can choose these options... Infinate, 0t,8,16,64t,auto... which do I choose?<br />
5. Same with DRAM Refresh Rate,<br />
choices are Auto, 15.6uSec, 7.8uSec, 64uSec, 64T, and I pick?<br />
6. DRAM Burst Rate<br />
I am wondering te same as the rest lol.<br />
Thanks guys for your services and I'll check back later have a nice one.<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/b5/b593994c_vbattach33598.jpeg"><img src="http://www.overclock.net/image/id/616773/width/525/height/525/flags/LL"></a>
Discussion Starter #2
Hey fellas I could really use the help if I am to tweak my rig out a bit more. I have an AMI Bios if that helps and I know my way around very well but I am just unsure what many of the features do. I also found another performance mode in the cpu section. The options in that menu are off, standurd, and turbo how should this option be set?
Bump!
Check out RAM parts I II and III...interesting read. I don't know if it will help your specific questions. Just trying to be helpful.<br><br><a href="http://arstechnica.com/paedia/storage.html" target="_blank">http://arstechnica.com/paedia/storage.html</a>
1 - 4 of 4 Posts
