IF = RAM Speed, it's just a reporting difference in HWInfo. Look at CPU-Z, it's showing the right number.
100.0 BCLK * 18 DRAM multiplier = 1800mhz/DDR4-3600
97.5 BCLK * 18 DRAM multiplier = 1755mhz/DDR4-3510
there's nothing wrong, your BCLK is just dropping. if it bothers you, take the BCLK off auto and set it to 100 (or slightly over if it still droops) and/or disable Spread Spectrum
